dany.1986
Junior Member level 1
Could someone please help me with understanding what the differential voltage is of the LTC2855 driver. From the datasheet I know that minimum VOD is 2 V and maximum VOD is VCC (3.3 V in this case). Maximum VOC is 3 V, so using the equations VOC+VOD/2 and VOC-VOD/2 and maximum values I get 4.65 V and 1.35 V with reference to ground. Am I right to say that because of that the voltage on pin Y is 4.65 V and on pin Z it is 1.35 V. The supply voltage for the device is 3.3 V. If I am wrong then could someone explain to me what the voltage would be on those pins, please? Another thing, if the voltage on one of those pins is 4.65 V then how is it generated, as the device supply is only 3.3 V?
