rudyb
- Joined
- Aug 24, 2013
- Messages
- 5
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 53
I have been asking this question but have not been able to find a reasonable answer for it.
When we have differntial signaling, we don't need a ground reference anymore, correct?
And that is because one of the pairs is acting as the ground.
But then I noticed that in different application when we are sending differntial signals from one unit to another, we somehow care about grounding, and I am not sure why?
For example, in RS-485 transactions, we normally connect a third wire as a ground reference.
Why do we need to send a third wire (ground) in RS-485 commmunications?
And in other forms (for example ethernet), we use isolation transformers for galvanic isolation.
It is not that the isolation transforms are only used for short circuit protection. I have read plenty of articles talking about that isolation transforms are also used to remove ground reference dependecny as well !!
Coming out of ethernet PHY, the signals is already differential pair (and to me that is well isolated, since there is no need for ground referecing). Then why do we even care about isolating it even more by the transformers?
I though that you could care less about ground reference differences when you are dealing with differential signals !!!
From as far as I can see, the receving end can have as much as ground difference as it wishes, and tha shouldn't matter for differntial signaling.
