different ways to implement mux
mr_vasanth
Member level 5
Member level 5
Bangalore, India, India
Method1:
assign y = sel ? a : b;
Method2:
case sel
1'b0: y = b;
1'b1: y = a;
endcase
Method3:
if (sel)
y = a;
else
y = b;
What is the difference between the implementation of mux using these three different methods ?
How do these methods treat 'x' and 'z' on sel input ?
After synthesis, will all these three methods produce same netlist ?
Using conditional operator, there will be an issue with select lines if they are x or z.
But when you use if else for implementing the mux, then x in select line then it will execute else condition.
For beter understanding, just implement the design and run the simulation once. Always a case block should have default statement in it.
Thanks,
Vivek.S
Found the difference between if-else and ternary/conditional operator based mux implementation.
1. if-else
during simulation, if the sel line is 'x' then the output y will be b.
2. ternary/conditional operator
during simulation, if the sel line is 'x' then the output y will be 'x'.
Coding Guideline: Never use “if-else” statement in combinatorial logic. Instead, use ternary/conditional “?” operator.
can someone explain how the case statement based mux will behave if the sel is 'x' ?
1. if-else
The case statement will output your default value. That is why you need a default.
If sel = x, a=1 and b=1 then the ternary will deliver an x even though hardware will deliver a 1. That is not good. You should also distinguish between glitching and glitchless muxes.
John Eaton
John, I understand your point about default case statement. But what will be the output if the case statement does not have a default case statement.
