It depends -what- is to be matched.
If you feed array A and array B identical current bias
then they don't care about orientation, local match
is still good and current mirror behavior is fine.
If you feed A and B a master gate bias voltage instead,
you should expect that they do not produce identical
current outputs because the FETs are likely shifted
differently, lithographically (for example gate may be
offset from contact lengthwise for A, widthwise for B,
so A may have more or less source resistance than B).
And you also are depending on ground net integrity,
longitudinal bias from I*R, if you ship voltage rather
than current across any significant distance.
Naturally "same is best". But you can make certain
compromises without much downside, if you make
others appropriately.
