different pulse signal using clk or syn
nil_kdm
Newbie level 1
Newbie level 1
i want to gen 1 us ipp pulse for every clk(which 4 khz freq by division using counter)
here program to generated the same..
these program run on simulation perfactly .
in hardware get clk but not getting 1 us pulse
please suggest me code......
and thanks for reply
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_arith.ALL;
use IEEE.STD_LOGIC_unsigned.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity dcm_counter is
Port ( clk1 : in STD_LOGIC;
clk : out STD_LOGIC;
ipp : out std_logic
end dcm_counter;
architecture Behavioral of dcm_counter is
signal count : integer :=1;
signal clk_in : std_logic :='0';
signal ipp_1 : std_logic :='0';
begin
process(clk1)
begin
if(clk1'event and clk1='1') then
count <=count+1;
if(count = 5000) then
clk_in <= not clk_in;
count <=1;
end if;
end if;
end process;
clk <= clk_in;
process(clk_in)
begin
if(falling_edge(clk_in)) then
ipp_1 <= '1','0' after 1 us;
end if;
end process;
ipp <= ipp_1;
end Behavioral;
I learned from some blogs that it is better to design synchronous circuit, and to avoid use "clk_in" here to control a sequential logic.
count <=count+1; this might cause your calculator exceeds you preset...
" ipp_1 <= '1','0' after 1 us; " this line of code is not practicable in hardware, merely useful for simulation at modelsim tool.
correct me if anything wrong, thx.
