suppose that I have a block whose task is adding 1 to its input and output the result after 1 clock delay; also suppose that the behavioral simulation worked just fine.
If the post-PAR (timing simulation) shows a different result, i.e. that the result comes out after 2 clock delays (see the attached figure), what could be the problem?
Sure. Actually the block performs a sum between two inputs. Here are its ports
clk: in std_logic;
reset: in std_logic;
en: in std_logic; -- enable
A1 : in std_logic_vector(7 downto 0);
A2 : in std_logic_vector(7 downto 0);
SUM12 : out std_logic_vector(8 downto 0)
while this is the main process
aws_p : process (clk,reset)
variable aws_tmp : std_logic_vector(8 downto 0);
begin
if reset='1' then
SUM12<=(others=>'0');
elsif (CLK'event*and*CLK='1') then
if en='1' then
aws_tmp := conv_std_logic_vector(conv_integer(A1) + conv_integer(A2),9);
SUM12 <= aws_tmp;
end if;
end if;
end process;
In the testbench, the inputs vary synchronously with the clock. Also, my constraint file contains only a period specification.
you might want to check the rtl diagram - see if ISE is treating aws_tmp as a signal rather than variable. Or just remove the variable assignment altogether.
The simulation in post #1 is missing one input signal. Also the exact timing relation of clock and input matters. It can't be seen from the waveform, we need to see the textbench code. It would be much clearer if you change the input data not exactly at the clock edge.
