YechielA
Junior Member level 1
I simulates a simple printed Inverted -F antenna at a frequency of 1.9 GHz using HFSS. I also measured the antenna in an anechic chamber.
The problem is that I get a large difference between simulated and measured results. While measured results show antenna efficiency of about 66%, measured results show no more then 27%. The printed antenna is printed on FR4 which is assumed to have a TAND of 0.02.
