differences between for...loop and for...generate
Binome
Full Member level 3
Full Member level 3
Lyon, France
Please tell me what difference there is between these 2 kinds of loop:
init1 : process(clk,rst)
begin
	init_loop : for j in 0 to N-1 loop
	if rst='1' then
		sigtmp_I(0,j) <= (others => '0');
		sigtmp_Q(0,j) <= (others => '0');
	elsif rising_edge(clk) then
		sigtmp_I(0,j) <= in_ifft_I(j);
		sigtmp_Q(0,j) <= in_ifft_Q(j);
	end if;
	end loop init_loop;
end process init1;
init2 : for j in 0 to N-1 generate
	if rst='1' then
	end if;
end generate init2;
Thank you.
Only the first one (with the process) is legal VHDL syntax. You can't use sequential statements outside a process.
Do you own any VHDL text books?
A process is for runtime decisions: "what should we do if this signal goes high?"
A generate structure is for compile-time decisions: "what modules should be included in the design and how should they be connected?"
Ok, and what about a component written to be simulated then synthesized? Shoul I make the runtime or compile-time decisions easier?
If it's supposed to be both simulated and synthesized, then all the limitations for synthesis apply. For synthesis everything has to be determined compile-time.
Nicely put,
But I think this statement tricked Binome into thinking that processes are meant for synthesizable logic only - which isn't true...processes can be used in simulation also...
Binome, think of "runtime" as everything that's "ticking" in your code and isn't associated with logic generation.
