HEADER
"PSFversion" "1.00"
"BINPSF creation time" "1564453319"
"simulator" "spectre"
"version" "17.1.0.307.isr6"
"date" "11:21:59 AM, Tue Jul 30, 2019"
"design" "(no title)"
"analysis type" "sp"
"analysis name" "boke"
"analysis description" "S-Parameter Analysis `boke': freq = 100 MHz"
"xVecSorted" "unknown"
"tolerance.relative" 1.00000e-05
"mode" "ss"
"number of ports" 2
"PORT2:r" 50.0000
"PORT2:num" 2
"PORT2:units" "Ohm"
"PORT1:r" 50.0000
"PORT1:num" 1
"PORT1:units" "Ohm"
TYPE
"sweep" FLOAT DOUBLE PROP(
"key" "sweep"
"S-Param" COMPLEX DOUBLE PROP(
"key" "SP"
SWEEP
"freq" "sweep" PROP(
"sweep_direction" 0
"units" "Hz"
TRACE
"s22" "S-Param"
"s12" "S-Param"
"s21" "S-Param"
"s11" "S-Param"
"cy22" "S-Param"
"cy12" "S-Param"
"cy21" "S-Param"
"cy11" "S-Param"
VALUE
"freq" 1.00000e+08
"s22" (-0.333333 0.00000)
"s12" (0.666667 0.00000)
"s21" (0.666667 0.00000)
"s11" (-0.333333 0.00000)
"cy22" (0.0200000 0.00000)
"cy12" (0.00000 0.00000)
"cy21" (0.00000 0.00000)
"cy11" (0.00000 0.00000)
END
