May 29, 2010 #1 R rashika17 Newbie level 2 Joined May 29, 2010 Messages 2 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,292 Can anyone explain in term of usage what is the basic difference betwwen synchronizer and lockup latch
Jun 3, 2010 #2 E eshwartt Junior Member level 3 Joined Oct 27, 2007 Messages 27 Helped 7 Reputation 14 Reaction score 8 Trophy points 1,283 Activity points 1,497 Hi Rashika, A Synchronizer handles situations where data needs to move from faster clock domain to slower clock domain or vice-versa whereas lockup latch doesn't allow data to cross between two clock domains. Regards, Eshwar.
Jun 3, 2010 #3 M muni123 Member level 3 Joined Apr 28, 2007 Messages 64 Helped 4 Reputation 8 Reaction score 2 Trophy points 1,288 Location India Activity points 1,625 A lockup latch is used to prevent data corruption caused by overwriting of new data over the present data before the clock edge occurs refer this post:
Jun 5, 2010 #4 R rashika17 Newbie level 2 Joined May 29, 2010 Messages 2 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,292 Thanks for answer, But lockup latch delays the data by around half cycle not stops the data to propogate. Please correct me if I am wrong. Thanks
Jun 7, 2010 #5 S somu.atluri Guest synchronizer flop is generally used to avoid metastability lockup latch is used to add a half cycle to avoid setup/hold issues between two flops.
