narayanb
Newbie level 1
What are the chances that ADS simmulations does not match with the actual measured results?
Got this problem when i designed a meander antenna in layout and simulated using momentum. A very prominent resonance appears at 200 MHz, which is completely missing in the measured results...
The antenna operating frequency is 200-800 MHz, designed to resonate around 300 MHz
