[SOLVED] difference between set_max_transition and set_input_transition
venugopala_0202
Junior Member level 1
Hello
Can anybody please explain the difference between set_max_transition and set_input_transition constraints?
set_max_transition sets the maximum transition time, a design rule constraint, on specified clocks, ports, or designs whereas set_input_transition sets max/min transition time attributes on the corresponding input port.
