Re: Difference between process file, rule file, runset file
process file: contains process (physical & technological) parameters
rule file: contains the rules for DRC, ARC (antenna rules check), extraction or LVS
runset file: contains a full set of conditions for a program to be run (e.g extraction, simulation), plus the locations (paths) of all necessary (input & output) files
