aashishsharma
Member level 5
Hi I am using 16 bit ADC Max1415. It boast of sampling rate of fckin/64MHz. I am using internal clock with 2.4576Mhz so sampling rate becomes 38.4 Khz. but output data rate as mentioned in the datasheet is 60Hz. I figured out code and everything for that ADC but at my end I am finally getting just 2 samples per second.
I dont think arduino code which I am using can create that much delay. So what does sampling rate means if we are not getting data at that rate?
thanks in advance
thanks in advance
