output stage voltage limit ota
I like to repeat some former answers and, more than that, give some helpful additional information:
1.) OPAMP: Differential high impedance input and very low impedance output (voltage source) and a very high gain.
2.) OTA: Differential high impedance input and rather high impedance output (current source).
Thus, the relation between output and input is current/voltage=transconductance gm which has a final value. As an important feature the value of gm in commercial OTAs can be varied by a current into a separate pin.
Application:
3.) Opamps always are used with external feedback in order to create amplifier, filter, adding circuits, integrators,...... (Of course, they can drive also capacitive loads up to a certain limit)
4.) OTAs are used normally without external feedback (although it is possible and allowed). They have better high frequnecy capability than opamps. The output voltage is simply output current times load impedance. Since gm can be varied the gain can be controlled by an external control voltage.
To understand the OTA function you can think of it as a more or less ideal transistor with finite transconductance.
