garimella
Full Member level 5
On/off control also takes feedback for processing and a PID also uses feedback to achieve its goal. Can we say that on/off is special type of feedback control where output hovers around a range of values.
Isn't ON/OFF the same as PWM, just with much lower freqeuncy?In my view, pulse width modulation isn't on-off control. It's continuous, e.g. PID, control combined with a modulator.
Not the same, I think. Consider e.g. an on-off controlled heater operating with low duty cycle. The average temperature will be considerably above the set-point (and vary with duty cycle respectively heat demand). A PI controller with PWM keeps the average process value at the set-point temperature.Isn't ON/OFF the same as PWM, just with much lower frequency?
