Difference between LDO and opamp
calculus_cuthbert
Member level 4
Member level 4
I have some basic questions regarding LDO and opamp based amplifiers:
1. When is a LDO used and why can't an opamp based amplifier be used? For e.g. I came across a sensor analog front end system. A bandgap was designed to generate a reference voltage of ~1.2V. But the ADC needed a 2.4V reference so a LDO was designed with the bandgap as its reference. My question is: Why was a LDO designed and not a non-inverting/inverting opamp amplifier?
2. In the same sensor analog front end, another reference was designed for the digital blocks. The reference was ~1.2V. Here also, a LDO was designed with the bandgap as it's reference. My question is why wasn't a buffer opamp used instead?
Could someone please help me understand why?
Thanks!!
