Hi All,
I have designed a simple DGS (Defected ground structure) band pass filer for 1.5-2 Ghz.
I tried to simulate in HFSS and MWO.
It took hours for only 5 frequency steps on both SW while a hairpin filter takes just seconds.
Does anyone know why is that so?
Thanks you...
If you have a solid ground plane, you can include it as a boundary condition.
If you need to mesh the ground plane, because it has holes, you have more unknowns = more complex problem.
Hi All,
Thanks you...
Try to set the coarse grid for the em simulations in AWR MWO-EMSight as it uses rectangular mesh...
If you have AXIEM option, try using it as it is faster than EMSight...
If you still have issues, upload MWO file (*.emp) here...
