If you are setting set_auto_disable_drc_nets -constant to false DC adds tie cells based on the max_fanout attribute of these tie cells. If you set the variable to false before your initial compile -scan, then Design Compiler connects the scan enable pin of every scan flop to a tie0 cell.
