kiranks9
Member level 3
DFT Questions
1)Is it recommend to have tri-state bus in the design, if so what precaution needs to be taken during design
2)Functionally it is taken care that the existing tri-state bus drivers can never create bus contention. Is this sufficient for Scan shift and capture? Do we need to take any extra care? Why?
3)If the entire design is a shift register, do you need scan insertion, explain
4)How do you ignore the block which is already scan inserted from re-inserting scan?
5)What is the purpose of latches at the end of scan chains and is there any impact, explain
