Srikanth Yakkala
Newbie level 3
1. In your design you have dual port memories each working at a different frequency. What is the clock frequency you use for testing (MBIST)?
2. When a failure is detected in parallel testing of memories, how do you know which memory is failing?
3. What are the extra pins needed for BIRA (Built In Repair Analysis) implementation?
4. What could be the possible reasons for scan chain failures during GLS (Gate level Simulation)? Other than setup issues.
5. Did you got any issues during timing simulation of MBIST patterns?
6. What are typical frequencies for scan shift, MBIST tests?
7. How is it different implementing MBIST logic for ROMs, SRAM, DRAMS, and register files? Can same controller handle all these? What are the typical issues faced?
8. What are the differences between IJTAG and JTAG standard?
9. What are the differences between Boundary scan and IEEE1500 standards? Other than Boundary scan is used for board level testing and the IEEE1500 for core based testing.
10. What is the effect of LOS method for testing delay faults on the tester?
11. What are the typical issues you face during timing simulation of scan and MBIST patterns?
12. What are copy and shadow cell? How are they useful?
13. What are the typical clock skew issues you faced during post layout/ timing simulation?
14. How do you implement DFT for a design have lot of Analog blocks? How to improve coverage?
15. How do you test at-speed faults for inter clock domains?
16. Are multi-cycle paths tested in the design?
17. Why do you need multiple-load patterns? What are its advantages over basic scan patterns?
18. What are the typical steps to improve coverage when our coverage target is not achieved?
19. Steps to fix broken scan chain issues during ATPG? Step by step procedure to find the issue?
20. What is sequential depth?
21. How to specify clocks for at-speed testing in encounter test or any other tool? What is the syntax?
22. In SDF we have 3 values best, typical and worst case? Best is for good processor, less temp , high vol and worst is reverse. What is typical?
23. What is split capture?
24. What Is the most challenging issue you faced? How you fixed it?
