device driver programming in c
akshay985
Member level 4
maharastra,india
i want to learn device driver programming in c how ddo we use it in windows and to program microcontrollers
You have two seperate requirements
1. Windows device driver programming - have a look at the codeproject tutorial
if you do start writing device driver use a seperate development PC in case it goes wrong an you corrupt the operating system
2. Programming microcontrollers - here you need to decide why you need to program microcontrollers, do you have an application in mind? that would tend to determine the type of microcontroller and IO devices
As horace1 said you should be clear and particular, What exactly you want?
1) Writing device driver for Windows Platform? Check MSDN it is very good
again there are good books available too. Even You can write drivers using C# too I saw a driver written using it.
2) Micro controller programming , Well you can use Any language if a compiler is available for that architecture and language.
If you mean writing driver for peripherals of a Micro controller system yes you can write it in C or any other language. For that you must have all the details of the Board and chips on it.
