hi...
i want to work with TMS320C6711 ...i have used a little bit of DSK provided by the TI... but now i want to develop my own board with some ADCs, DACs, DSP programming circuit...and few more similar peripharrals...
can anyone help?
bye
Hi Khan
I known alittle bit in DSK TMS320C6711 and I'm doing acoustic echo cancellation (AEC) using it
Can you introduce some ebook about AEC or C code programming with TMSc6711
Thanks
Regards
The first thing you should considerate is the balance between the memory space and speed/computing capability. If you prefer speed, you have to use the internal data and code memory. So your code is not too large.
I only have paper mode "DSP Applications Using C and the TMS320C6x DSK".
Sorry....
But you can download this book from this network station.
Digital Signal Processing and Applications with the C6713 and C6416 DSK (Topics in Digital Signal Processing)
oh I don't have enough points and enough day.
Eric Lin have you ever read acoustic echo cancellation in communication using DSP before.I really need some reference books in this field,especially in Adaptive filter
regards
All books mentioned above only tell us about software programming and they use a lot of library for DSK (BSL library).If you want to design board on your own with DSP,ADC,DAC,Flash...,I think you can refer to DSK schematics and read application notes of TI C6x.It takes time but let's try ! Cheer
Try this website dsp-book.narod.ru/books.html.
There's no Simon Haykin book but you can see adaptive filter in DSP a computer Science perspective Jonathan Stein.
