[SOLVED] developing a library for gpio lpc1768
h.galeh
Member level 3
Member level 3
Tehran, Iran, Iran
I am defining a library for gpio easeing work . so that you can program micro as easy as possible without hardware challenge
but its macros has problems
please help to make it
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
#ifndef __GPIO_H
#define __GPIO_H
#define PORT0 1
#define PORT1 2
#define PORT2 3
#define PORT3 4
#define PORT4 5
#define PIN(n) (1UL<<n)
#define SELECT_PORT(n)
    #if n==PORT0
        #define PORT             ((LPC_GPIO_TypeDef      *) LPC_GPIO0_BASE    )
    #elif n==PORT1
        #define PORT             ((LPC_GPIO_TypeDef      *) LPC_GPIO1_BASE    )
    #elif   n==PORT2
        #define PORT             ((LPC_GPIO_TypeDef      *) LPC_GPIO2_BASE    )
    #elif n==PORT3
        #define PORT             ((LPC_GPIO_TypeDef      *) LPC_GPIO3_BASE    )
    #elif n==PORT4
        #define PORT             ((LPC_GPIO_TypeDef      *) LPC_GPIO4_BASE    )
    #endif
   #ifdef PORT
    #define KEY(n) {((PORT->FIOPIN&PIN(n)) == PIN(n))}
    #define SET(n) {PORT->FIOSET = PIN(n)             }
    #define CLR(n) {PORT->FIOCLR = PIN(n)             }
    #define CONFIG_OUT(n) {PORT->FIODIR= PORT->(FIODIR|PIN(n))}
    #define CONFIG_IN(n) {PORT->FIODIR= (PORT->FIODIR&~PIN(n))}
  #endif
#endif
h.galeh
Member level 3
Member level 3
Tehran, Iran, Iran
it is not necessary to make a library for it
since CMSIS is a complete set of codes available for configuring pripherials
to use it
go to examples of IAR or keil
refer to CMSIS folder
folder named "driver" is its library there.
you can freely add it anywhere inside your code
