Aug 14, 2019 #1 S SS1_Raptor Junior Member level 1 Joined Feb 16, 2019 Messages 17 Helped 0 Reputation 0 Reaction score 0 Trophy points 1 Activity points 148 Hello friends Is there a way to detect the ferrite ring power without the datasheet? I have a green ring ferrite inner diameter = 37mm External diameter = 63mm Height = 25mm Thanks a lot
Aug 14, 2019 #2 E Easy peasy Advanced Member level 6 Joined Aug 15, 2015 Messages 4,746 Helped 1,402 Reputation 2,804 Reaction score 1,933 Trophy points 1,393 Location Melbourne Activity points 26,219 put 5 turns on it and measure the L, from that you can work out the Ur, if it is quite high ( > 3000 ) it is likely a common mode choke material - not a power ferrite.
