shreeharshakg
designing LUT using VHDL
Sir, i am designing DA-FIR filter using sysgen. now i have designed FIR filter and i am getting the coefficient values. they are real numbers, eg: 0.27655, -0.0976,...... now i want to design an LUT which should do the following :
* address is 0 to 15, 4-bit and let the coefficients be w0,w1,w2,w3. w0->0.273, w1-> -0.093, w2->0.093, w3-> -0.273 .
* for a3a2a1a0
0 0 0 0 -> 0
0 0 0 1 -> w0
0 0 1 0 -> w1
0 0 1 1 -> w1+w0
0 1 0 0 -> w2
* in the above shown way, depending on the bit set , it must add/subtract the coefficients and store the results.
* here i'm finding difficult in add/sub of real numbers and converting it into bits.
- how can this be done using VHDL code.. can you please help me in getting through this.
thanking you sir,
yours sincerely,
Shree.
* for a3a2a1a0
0 0 0 0 -> 0
0 0 0 1 -> w0
0 0 1 0 -> w1
0 0 1 1 -> w1+w0
0 1 0 0 -> w2
thanking you sir,
yours sincerely,
Shree.
