[SOLVED] designing ISP header for STM32F030F4P6
pcsandhya82
Member level 3
Member level 3
Bangalore
Hello,
I am designing a board using STM32F030F4P6. I have to use STM32F0 Discovery board STLINK for ISP. Checking the schematics of Discovery board, I found out that the ISP connector (SWD) is connected as follows:
1.3.3V
2.SWCLK
3.GND
4.SWIO
5.NRST
6.PB3 of the STM32 controller on board.
Now, I have trouble understanding the 6th connection. the signal name is given as T_SWO and it is connected to PB3. what is this signal? In TSSOP 20 package of STM32F030F4P6, this pin(PB3) is not there. so where should I connect 6th pin of ISP header? or can i leave it open?
Attachments: MB1034: Discovery board schema
DM00088500.pdf: STM32F030F4P6 Datasheet
DM00039193.pdf:STM32F051xx Datasheet
  • MB1034.pdf
  • DM00088500.pdf
  • DM00039193.pdf
Got reply from STMicro forum.
"PB3 SWO is typically used in support of the SWV (Serial Wire Viewer), as far as I'm aware the Cortex-M0 does not support this functionality (Debug/Trace), or JTAG, so the pin can be left unconnected.
If may be connected in the schematic due to the way ST shares a common footprint over several processor families, allowing migration up and down the feature/power/cost line.
I, personally, would opt to use the standard 10-pin 0.05" pitch ARM programming header over the ST ISP one."
