Designing antenna for NXP ICs
viral8387
Newbie level 3
Hi guys,
I am recently start working on MFRC522, I want to know that will MFRC522 give read-write range more than 7cms?
I am also struggling for antenna design. Please anyone can guide me to design antenna for NXP ICs.
Regards
Viral Chavda
FvM
Super Moderator
Staff member
Bochum, Germany
mifare coil
The Pegoda reader (a NXP reference hardware) typically achieves 10 cm range with a circular coil of about 10 cm diameter. Larger ranges should be possible with larger coils, possibly a power amplification may be required. The reader should be designed in a way, that the specified ISO 14443 field strength of 1.5 - 7.5 A/m is achieved within the intended operation volume.
All NXP designs are using a resonant coil interface network as shown in the MFRC522 data sheet. It's properties can be analyzed by basic network equations or modelled with analog simulators.
NXP is also providing application notes under a NDA agreement.
viral8387
Newbie level 3
interfacing antenna with mfrc522
Hi
Thanks for your valuable reply.....
I have documents of nxp for antanna design. I have designed one board with CLRC632 with square antanna of 2 turns having wire diameter 1mm , wire spacing 0.5mm (50mmx48mm). Now the problem occur that i am not able to tune that board using that document. Can you guide me to tune it?
EMC filter , RX and Vmid section is same as mentioned in NXP documents.
VMID---------- 820E-----
100n |
GND |
RX----------------------------560E--1n--
Tx1-----1uH-----------------------------------
68pF
GND-------------------------------------------
68pF
Tx2-----1uH-----------------------------------
Regards
Viral Chavda
FvM
Super Moderator
Staff member
Bochum, Germany
mfrc522 tx2
Both parallel capacitor pairs have to be tuned while the series capacitors are setting the impedance transformation ratio. 68 pF surely isn't correct, it's 2 x 68 pF each in the NXP application note.
In my opinion, a 50 mm coil should rather have 4 than 2 turns, and it's not suited for distances above 50 or maximal 70 mm anyway, even if perfectly tuned.
viral8387
Newbie level 3
mfrc522 antenna design
Previously i had design antenna with 4 turn but its inductance are getting more than NXP recommendation and also i face difficulty while i am tuning it so i change turns from 4 to 2. As you told should i put two parallel capacitor in EMC filter of 68pF. m i right?
I m following this circuit for antanna matching circuit design.
FvM
Super Moderator
Staff member
Bochum, Germany
mifare field strength
I think, it can work with 2 to 4 turns; I don't know wich variant will achieve higher field strength, the tuning (C1/C2) has to be different of course. C0 is 2*68 pF in the NXP reference design.
