The capacitor, needs to charge up via the FET switch and the output impedance of the first Op amp during the time the sample pulse exists. So if its too large it never charges to the correct value. When the sample gate is closed the capacitor then discharges through the back resistance of the FET and the input impedance of the output OP amp, so if the capacitor is too small, its voltage will decay giving a "low" value for the stored voltage.
Frank
You cannot just ask for values!
Run simulations first.
You know fs, power supply, and input range, then you have do run sims to make sure the 1st opamp amplify the input to the desired range and filter the outofband noise. Then decide the switch and the cap to make sure it settles in less than half the clock period. Then the bandwidth and accuracy and stability of the 2nd opamp can be decided.
To decide about component values, we need to know the OP and switch transistor types first. In addition, there's no particular need to give the input stage a gain > 1, it can be configured a s buffer similar to the output stage as well.
A reasonable capacitor value depends on the signal time scale, sample rate and available acquisition time.
You haven't specified any performance criteria so how can anyone specify values? You need to define the range of input signal frequency and the sampling rate you want. As with any design there is not a single right answer. The sampling capacitor needs to be large enough to hold the value with minimal droop (which needs specifying) but small enough so it can be charged quickly by the preceding opamp/FET without causing instability in the opamp due to accessing capacitive load. Provided a CMOS sample buffer is used, something like 100pF might be a reasonable starting point for experimentation. You may find charge injection problems from the FET if you use a MOSFET so that may force you to increase the capacitor.
my advisor want a pulse ampilitude modultion by using sample and hold circuit without any special criteria , just he wants to see the circuit if it works or not
"how can i run the simulation with out values !!!!!!!". Draw circuit, stick in any values, run simulation, inspect results, if not satisfactory repeat with different values. Eventually you will learn what effects what - Brilliant!
Frank
