design question on wireless
EchoAngel911
Newbie level 3
Hello Everyone,
I am in Canada and currently I have this project to complete.
I want to transmit the s video + the audio L and R. The other end should receive back the s video + the audio L and R.
I know the S video has mainly the critical Y and C signal. In total, I would have to transmit 4 unique signals. As such I was thinking of OFDM to allow the broadcast of multiple signals.
As such, I guess
I would convert all 4 signals into 4 digital output,
send it into a IFFT block,
parallel to serial
guard interval insertion
transmit the OFDM signal
receive the OFDM signal
guard interval removal
serial to parallel
FFT the data
then digital back to analog
I just like to get exactly/most of the data back (that's why i'm using OFDM currently). This device would ideally be used for transmitting from tv to pc (with tv tuner card). I know I should not even try to design everything from scratch. I need to process everything like real time + fast.
I do not know the baud rate for s video. Can you guys recommend any modules/pieces I should get to satisfy my requirements?
I can spend at least 500 - 1000
The best way is to do some revers engineering. There are few products on the market that do exactly what you want to do. But one take it appart and see what they did.
If you want do build something of your own, then ( of top of my head ) i would take a s-video with soud decoder that converts it to parrlel or serial ( prefer serial ). This information you will transfer by RF ( you need very fast RF for all this informaiton ) and do the revers on the other side.
Afcourse this methode needs to be thought of much more...
Good luck.
