Design PCB for Android Capable Board
maxcode360
Newbie level 2
Newbie level 2
Hi !
I am looking for a professional embedded designer to consult over an electronic project.
Requirements :
1. ARM based MPU Board needs to be designed (Preferably running at 1+Ghz , Dual core).
2. Minimum 1 Gb RAM , 4Gb External Storage(with de-attachable uSD card).
3. Peripheral/features required on board -
a. SIM card support with Network Access for internet and calling.
b. Bluetooth and Wifi capable.
c. Micro - USB capable for Data Transfer from PC.
d. Re-Chargeable battery support,preferably from micro-USB port.
e. Audio Output
f. Capable of working with small colored LCD screen (around 36mmX36mm)
4. Inbuilt Mechanism for Flashing/Debugging Code (like JTAG).
5. Maximum Board Size is 36mmX36mm
( This is a must, if required a stack of two PCB's can be used,but not more than that)
6. Resilient to Electro Magnetic Interference , and must follow appropriate standards to protect against noisy environments as well as minimized emissions.
***Only Schematic Files and PCB layout files Required ***
Please contact with your resume and mention similar projects done .
Only those candidates will be accepted which will present a strategy to solve this problem.
Your strategy must contain the components you plan to use.
If you are accepted you will be free to choose your price.
Thank you for your time !
Additions : The Hardware is required to run the Android OS.
hi:
I want to help you, i have been used OMAP....,can you any question to ask,please cantact me;
my email:johnstonick@outlook.com, I will give you details that you wanted.
