This schematic works as input 1.8V then output is 0. When input is 0V out is -3.6V.
I need in opposite way.
A trivial solution would be to invert your Pulse signal.
Besides being simpler, the circuit I gave achieves what you are specifying, simulate it please and see by yourself.I need to design a switch which works such that when we give 1.8 as the control signal which is my input as shown in the picture it should give me -3.6V. and when I give 0 at the input I should get 0 at the output.
Basically I need a configuration as transistors are stacked as shown below in the picture.
VDS of both the transistors are more that -3.5V which is not okay. CMOS 180nm technology. VDD is 1.8V.
please guide me with the solution.
Does your process offer 5V (I/O) transistors?
BTW: In a bulk CMOS technology (p-substrate) you can't use negative voltages. The p-substrate must be your most negative potential.
If your process offers only transistors which can stand max. 1.8V , it should be clear that you chose the wrong process for your task.
And remember: for bulk p-substrate CMOS processes, the p-substrate must be the most negative potential.
This does not work:
I need same type of switch but in opposite way. Input 0 then output 0. When input 1.8V then output -3.6V.
By the way the first comprehensible schematic in this thread, showing input, output, power supply...you could try something like that
If you think you can realize this with your process - you didn't tell if you'd use a p-substrate, an n-substrate or an SOI technology - you could try something like that:
View attachment 144255 Note the N3:N4 aspect ratio!
could you please give me a schematic as if input 0 then output 0, but when input 1.8V output should be -6V ... Please guide me with the solution
In this case you can renounce on N3, but you need a huge aspect ratio for P1:N4 .
For P1 & N2 you need transistors which can stand at least 8V (and for the others at least 6V , of course). And an SOI process, I'd think.
Thanks a lot for this...I agree..But the problem is i am using CMOS 180nm process....1.8V is the max...
please help me with some other circuitry...I am also trying...but ...
The problem is ... with a 1.8V process you cannot realize an 8V circuit on the same chip. The same applies for your -6V charge pump. You either need a process which offers min. 8V transistors (perhaps an SOI process with isolated substrates), or you have to realize the -6V charge pump and its switch externally.
