Design of bias circuit for OP-AMP
wael_wael
Full Member level 4
hi every body
i am starting design of bias circuit, it is necessary the bias circuit have phase margin and bandwidth same the op-amp
regards
bias circuit just need low bandwidth
Which type bias circuit you used. Is there closed loop in you bias ciurct. Don,t care the phase margin if no closed loop. And the bias's bandwidth is not related to OP usually. As bias circuit supply DC bias usually.
as long as you are not using a loop to regulate the bias, there is no concern of phasemargin for biasing circuit.
wael_wael said:
hi every body
regards
bias circuit needs no phase margin
Could you please tell me some types of bias circuit? I just know the bandgap reference and the current source bias. Can you give me more hint?
