I am trying to design a surface resistance tester. Typically such an instrument uses a high voltage between probes (100V or 10V, depending on resistance value) and it is capable of measuring values from 1 kohm to above 100 Gohm (precision is not essential, a 10% would be ok). My intention is to use a linear ohmeter circuit, so I can convert resistance directly to current or voltage and display it digitally. I am looking at measuring the high end of resistance (from 10 Mohm to 100 Gohm).
After checking some circuits, one possible method relies on using an opamp. The gain of an opamp in inverting configuration is Vout = -Rf/Rin*Vin (Rf is the feedback resistor, Rin is the input resistor and Vin is the applied voltage to input). So, if I connect the test probes in the feedback loop of an opamp, I could get an output voltage proportional with the resistance to be measured. But the test voltage would be limited to the supply voltage of the opamp (it would be nice to use a 9V battery to supply the whole circuit). How can I have 100V test voltage between probes. The 100V can be obtained with a DC-DC inverter.
Perhaps there are better methods than this one.
Thanks,
Nick
