rfndmw
Member level 4
nec transistors ads design kit
I am trying to design an amplifier at 2.4 GHz using NE4210S01 HJ FET...the problem is the data sheet does not have the S-paameters for this frequency..though it does for 2 and 2.5 GHz...I have downloaded the design kit...do i need to use the spice model file again in ADS and how do I go about obtaining the S-parameters at 2.4 GHz..I also need to design a mixer at the same frequency using the same transistor..and I have the non-linear model on the datasheet...is it taken care of when I use a design kit...and also...the S-parameters in the file in design kit are not the same as those on the datasheet...so I am not really sure which ones to use...any help would be appreciated...thnks
