Design dual band microstrip antenna in CST microwave Studio
khilji3774
Junior Member level 3
Famagusta, Cyprus, Cyprus
Hi....
anyone who can help me how to design a dual band microstrp patch antenna. what are the necesarry steps which i should do. what formulas should be considered and the dimensions calculation.
It should be in 2x array form. First, i think you should design the antennas individually according to your desired frequency and then combine them both using a power divider.
You can refer to Balanis book or any other microstrip patch antenna books for further research on microstrip patches and on how to design them.
Maybe these links could help you
http://www4.ncsu.edu/~trharris/files/text/Harris-740PatchProj.pdf
http://www.ijecse.org/wp-content/uploads/2012/08/Volume-1Number-2PP-230-238.pdf
All the best
Positron89 thank you so much i will surely check these documents, but i want to acheive this dual band with the help of slots in the patch? do u have any information about this?
Previously I managed to get dual frequency on a single patch by experimenting with random slots on the patch itself. I could share some links where the researcher actually manage to achieve dual frequencies using multiple slots.
https://www.jpier.org/PIER/pier120/29.11090202.pdf
"Elliptical Shaped Antenna With Parasitic Superstrate" -IEEE Paper
"The Effects of Parasitic Superstrate Elliptical Shaped Antenna without Dots Element" -IEEE Paper
All the best
Thank you so much....
I also tried some random slots but is there any formula through which we make slots of some specific dimension to get the desired resonant frequencies?
Reactions: shaid
    shaid
I'm not sure of whether there are any particular formulas for slots designing. Slots such as v-slot and etc probably has specific formula especially in terms of bandwidth enhancements for the patch. For resonant frequencies, as far as I know we usually go for the size of the patch. What are the resonant frequencies are you going for ?
Reactions: shaid
    shaid
I see..
If slots are the only option for your design, I suggest that you could post a new thread on the topic regarding on dual frequencies slots for the antenna. It may get more responses.
All the best
