May 5, 2008 #1 X XHL Newbie level 5 Joined Apr 28, 2008 Messages 9 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,330 Of course one option is to be aggressive on process such as using 65nm. However any new idea can be used on that such as custom cells ...........
May 5, 2008 #2 I ieropsaltic Full Member level 4 Joined Sep 25, 2006 Messages 199 Helped 64 Reputation 128 Reaction score 18 Trophy points 1,298 Activity points 2,595 Different high speed logic families can work at the GHz range. For example, current mode logic (CML) and dynamic logic. Actually, these two families are used for frequency dividers for PLLs working at multi-GHz frequency.
May 5, 2008 #3 R rosaeidi Full Member level 2 Joined Dec 19, 2006 Messages 143 Helped 4 Reputation 8 Reaction score 2 Trophy points 1,298 Activity points 2,129 Hi I thinks the the delay of an inverter in every process is the corner case. We can design a ring oscillator with only three inverter.
