I would (for the moment) forget about the 28MHz part and use Google for basic Colpitts circuit designs. You will see many that use op-amps or transistors but the basic structure will be the same. You can also narrow the search down to those that use mosfets (such as
http://www.datasheetdir.com/Nanopower-Lc-colpitts-Oscillator-Circuit+Application-Notes found at random).
After that you can start to design one that will oscillate at the frequency you are interested in.
What do you want it for? Are you looking for frequency stability, or low component count or what?
Susan
