Re: codes
hi
as you know in gray code every value differs from the next only in one bit.
for example a binery value must change from 0111 to 1000.if one bit changes slower than the others a middle-value 1001 is created which may be undesireable.this problem may not accure when gray codes are using because only one bit have to change.
Added after 7 minutes:
hi
