The bandwidth (response time) depends on the open-loop characteristics as well as on the feedback factor "beta".
For both configurations this factor "beta" is nearly the same (because for constant "beta" both gain values differ only by "1")
i deduced the transfer function for both the configurations with single pole. what i observed is, the non inverting configuration has higher gain compared to inverting configuration and the pole locations are same in the closed loop.
the problem is now simpler,
we have two frequency responses one with higher gain , both having same pole location. now can u tell which is faster
The speed of opamp (if you mean bandwidth and slew rate by this) doesn not depend on feedback configuration unless feedback network includes some reactive components (capacitor, inductor). Only on the parameters of the opamp itself.
It is not the closed-loop gain that determines speed but the gain of the open loop and its bandwidth (simply "loop gain"). And the loop gain is determined by the feedback path only.
Some comments are necessary:
* The shown equations are somewhat confusing. What is Hs?
The non-inv. gain is twice the inv. gain for 50% feedback only - that means: Gain (non-inv.)=2 and gain (inv)=-1.
* According to the drawing the same feedback factor applies to both circuits. Hence, the same loop gain bandwidth (as indicated in the drawing).
Hence, the same small-signal response.
for the second image i attached,
i assumed 50% feedback only.
it means gain of non inverting =2 and that of inverting is 1(phase is 180 deg)
as u said same feedback factor for both circuits.
i took the closed loop response of both configurations as (1/(s+1)) and (2/(s+1))
i found the output response for step input.
in that the output raises fast in non inverting configuration as it has higher gain(a multiplication factor of 2).
in that the output raises fast in non inverting configuration as it has higher gain(a multiplication factor of 2). so non inverting configuration is faster
It`s just a matter of definition.
As mentioned before: Both configurations reach their small-signal steady-state output within the same time period (settling time constant) - determined by the available bandwidth (which is equal).
However, that means that the circuit with higher gain has a lower rise time.
So - you have the choice which of the both parameters you are using to define the property "fast".
Sorry, I have made an error: In my last posting I mentioned the term "rise time". That`s not correct. It should be "slope" of the rising signal.
To make it clear, take the following example:
Excite a simple passive RC lowpass with a 1V-step and a 2V-step.
In both cases, the settling time is equal (of course) but the slope is different. But I think, it is not appropriate to say "one configuration is faster than the other one".
