Daniel20048
Newbie level 2
Hi
I try simulate demodulator based on full wave. The carrier frequency is 8MHz, Amplitude 1V. The modulated signal frequency is 100Khz, level is 100mV.
I attach my schematics (simulation created by LTSPICE,), and waveform at de-modulator output.(Zoom out and zoom in)
The input signal is differential and U4 modify it to single ended, this is vout1.
Vout2 is the output of the full wave demodulator comprised of U1,U3, and you can see the signal is distorted.
I use LTC6247, gbw=180MHz, slew rate is 90V/us.
So I think the decvice fit.
The diodes are BAT54.
At lower frequency (Carrier frequency=0.8MHz) VOUT2 look O.K.
Please advise if this is circuit problem or devices selection.
Thanks!!!
Thanks!!!
