Delta pattern - Array design
Lupin
Full Member level 6
Full Member level 6
Italy
Hell Rf people,
I have a question for u:
I'm designing an array antenna in order to synthetize a "delta" pattern defined as it follows:
- null for teta =0;
- Gain = 10 dB for teta= +/- 27 degress.
I'm using an array of patch antennas defined as it follows:
Positions:
1 (0,0)
2 (18.75,0)
3 (9.375,-9.375)
4 (9.375,9.375)
Excitations:
1 (0 dB, 0 degrees)
2 (0 dB, 180 degrees)
3 (0 dB, o degrees)
4 (0, 180 degrees)
At the moment I'm considering an isotropic radiator.
Unforntunately, I don't have a e.m. simulator with me.
Can anyone tell me if this configuration can work?
Frequency is at 1.6 GHz and Bandwidth is very very small.
Thanks in advance,
Lupin
