Solar000
Member level 2
Hello, i am trying to use Delay_ms function with a variable which i calculate from another function and i want to pass it to the function with the Delay_ms.
I know that Delay_ms is better from Vdelay and works with numbers and constants.
So this works :
I want to do this :
I want to make one time the calculation and pass the result from one function to another.Why it doesn't work?How i can do this, instead of calculating const y=60000/x;
to every function?
So this works :
const unsigned long y=60000/x;
Delay_ms(y);
I want to do this :
#define Tempo 60
void main(void)
const unsigned long DPBms=y(Tempo);
Tetarta(DPBms,4);
const y(const x) {
return (60000/x);
void Tetarta(const unsigned long Delay,int metra){
int i;
const unsigned long Tetarto=Delay; //it doesn't work.Works only if 60000/Tempo ; instead of delay variable.Also tried const Tetarto,*Delay;
metra=metra*4;
for(i = 0; i < metra; i++){
Delay_ms(Tetarto);
Movement();
to every function?
