Led1 Alias P1.0 ' Led1 alias connected to pin P1.0
Led2 Alias P1.6 Led2 alias connected to pin P1.0
Config Timer0 = Timer , Gate = Internal , Mode = 1 'Config timer 0 as 16bit timer
Enable Timer0
---varijables---------------------
Dim Flag As Byte
Dim X As Integer ' parameter of function "delayy"
Declare Sub Delayy(x As Integer) ' delay function with parameter x
Dim Miliseconds As Integer
Enable Timer0
'main program
Do
--' first delay of 10ms (one call of fuction is 1000uS = 1ms)---'
Call Delayy(10)
If Flag = 1 Then
Led1 = Not Led1 'blink P1.0
Miliseconds = 0
Flag = 0
End If
--' second delay of 5ms (one call of fuction is 1000uS = 1ms)---'
Call Delayy(5)
If Flag = 1 Then
Led2 = Not Led2 ' blink P1.6
Miliseconds = 0
Flag = 0
End If
Loop
End
subroutine Delayy
Th0 = &HFC 'initialization registers for overflow: 65536 - Hex. FC17 (64535)= 1000 microseconds
Tl0 = &H17
Start Timer0 'start timer
Incr Miliseconds 'increment miliseconds
If Miliseconds = X Then ' forwarded parameter x ( 10 or 5)
Flag = 1
Stop Timer0 ' timer stoped
End If
Return
End Sub ' ends subroutine
