defining the input of a microcontroller
Ogu Reginald
Full Member level 6
Full Member level 6
Nigeria
www.facebook.com
Hi everyone, below is a portion of my code on how I defined the input of AT89S52 microcontroller. Also attached is the circuit diagram. My questions are:
1. Is it necessary add a resistor between the input of the microcontroller and the ground in other to make the input of the microcontroller be well defined at all times.
2. Must I always write a logic one in the code in other to configure the pins as input.
3. The way I defined the pins in the main program, is it alright.
Please if there needs to be adjustment anywhere let me know, thank you Code.jpg
Here is the code:
#include<reg51.h>
sbit low=P1^0;
sbit high=P1^1;
sbit danger=P1^2;
sbit emergency=P1^3;
void delay(int delay_time) // Time delay function
int j,k;
for(j=0;j<=delay_time;j++)
for(k=0;k<=1000;k++);
void main(void)
low=high=danger=emergency=1;
1, no need. the i/o pin by default will be in logic 1 for i/p.
2, no need for 8051. but its good practice to follow
3, ok
