big_fudge98
Member level 2
Hello everybody,
I am doing some EM simulations using ADS Momentum (ADS 2021) in the Cadence Virtuoso (IC618) layout environment. From what I understand, the way a port is defined (point/edge) can have different impacts on the results, right? Is there any way to define a port as a rectangle?
The particular case I am trying to simulate is as follows: I have a signal line feeding the M6 layer at an edge. This signal is then connected to M1 through a via stack. So, M6 receives excitation along the edge, while the whole M1 sheet receives the excitation. I was wondering how to define the port at M1. I feel some sort of rectangular port definition is required, but I can't seem to find this option anywhere.
Thanks.
Thanks.
