Defining port bits in mikroc
swapan
Full Member level 4
Full Member level 4
Kolkata
Hi friends,
In assembly language, particular bit of a I/O port could be defined as '#define Relay - PORTA,1'. In mikroC, how this bit could be defined so that in the code, if the respective bit of the port requires to be set, it could be done as 'Relay = 1' or otherwise.
regards
swapan
TRISA = 0; //set all pins on port A as output
TRISA = 1; //set all pins on port A as input
TRISA.F1 = 1; //set pin 1 as input;
TRISA.B1 = 1; //set pin 1 as input;
PORTA.F3 = 1; //Set 1 for bit 3
PORTA.B3 = 1; //Set 1 for bit 3
RA0_bit = 1; //Set 1 for bit 0;
