Micro Lover
define ports
I m using AT89C51 for digital clock, with external Pulse.
i want to set the port0-1-2 for parallel data, and port3 for serial data
the problem is to define the port as input or Output
Master Clock
port0 for input ; Full 8 bit Port
port1 for output ; Full 8 bit Port
port2 for output ; Full 8 bit Port
port3 for output (to send serial data)
Slave Clock
port0 for output ; Full 8 bit Port
port3 for input (to receive data)
The main problem is to define any port a input or as output
I m sending my source code please inform me any type of errors
----------------------------- Source Code ----------------------------------------
org 00h
;Set up Timer 1
MOV IE, #0 ; Disable all interrupt
MOV TMOD, #020h ; Timer 1: Mode 2 (8-bit reload)
MOV TH1, #230d ; Reload value for 1201, SMOD = 0
MOV TL1, #230d ; Make first time-out correct
ANL PCON, #07fh ; To make SMOD =0
;Set up serial ports
MOV SCON, #50h ; Timer 1 : Mode 1 (vari baud) and set receive enable
SETB TR1 ; Start timer 1
mov r1, #6d
mov r2, #91d
mov r3, #63d
mov r4, #63d
MainLoop:
setb p0.7
mov r7, #90d
SubLoop:
mov r6, #90d
InnerSpot:
jmp DisplayData
InnerSpot1:
djnz r6, InnerSpot
djnz r7, SubLoop
clr p0.7
mov r7, #90d
SubLoop1:
mov r6, #90d
InnerSpot12:
jmp DisplayData
InnerSpot11:
djnz r6, InnerSpot12
djnz r7, SubLoop1
jmp MainLoop
DisplayData:
mov C, p2.7
orl C, p0.7
mov b, r1
mov p2, b
JNC Skip1
mov b, #254d
mov p1, b
Skip1:
mov b, #255d
mov p1, b
mov b, r2
mov p2, b
JNC Skip2
mov b, #253d
mov p1, b
Skip2:
mov b, #255d
mov p1, b
mov b, r3
mov p2, b
JNC Skip3
mov b, #251d
mov p1, b
Skip3:
mov b, #255d
mov p1, b
mov b, r4
mov p2, b
JNC Skip4
mov b, #247d
mov p1, b
Skip4:
mov b, #255d
mov p1, b
jnb RI, CheckReturnPoint
clr RI
mov a, sbuf
cjne a, #246d, CountCountinus
mov r0, #0d
CheckReturnPoint:
mov c, p0.7
jc InnerSpot1
jnc InnerSpot11
CountCountinus:
inc r0
DigOne:
cjne r0, #1d, DigTwo
mov r1, a
Jmp DisplayData
DigTwo:
cjne r0, #2d, DigThree
mov r2, a
Jmp DisplayData
DigThree:
cjne r0, #3d, DigFour
mov r3, a
Jmp DisplayData
DigFour:
cjne r0, #4d, CheckReturnPoint
mov r0, #0d
mov r4, a
Jmp DisplayData
End
Master Clock
Slave Clock
org 00h
;Set up Timer 1
mov r1, #6d
mov r2, #91d
mov r3, #63d
mov r4, #63d
MainLoop:
setb p0.7
mov r7, #90d
SubLoop:
mov r6, #90d
InnerSpot:
jmp DisplayData
InnerSpot1:
djnz r6, InnerSpot
djnz r7, SubLoop
clr p0.7
mov r7, #90d
SubLoop1:
mov r6, #90d
InnerSpot12:
jmp DisplayData
InnerSpot11:
djnz r7, SubLoop1
jmp MainLoop
DisplayData:
mov C, p2.7
orl C, p0.7
mov b, r1
mov p2, b
JNC Skip1
mov b, #254d
mov p1, b
Skip1:
mov b, #255d
mov p1, b
mov b, r2
mov p2, b
JNC Skip2
mov b, #253d
mov p1, b
Skip2:
mov b, #255d
mov p1, b
mov b, r3
mov p2, b
JNC Skip3
mov b, #251d
mov p1, b
Skip3:
mov b, #255d
mov p1, b
mov b, r4
mov p2, b
JNC Skip4
mov b, #247d
mov p1, b
Skip4:
mov b, #255d
mov p1, b
clr RI
mov a, sbuf
mov r0, #0d
CheckReturnPoint:
mov c, p0.7
jc InnerSpot1
jnc InnerSpot11
CountCountinus:
inc r0
DigOne:
mov r1, a
Jmp DisplayData
DigTwo:
mov r2, a
Jmp DisplayData
DigThree:
mov r3, a
Jmp DisplayData
DigFour:
mov r0, #0d
mov r4, a
Jmp DisplayData
End
