I'm trying to define a set of coefficients for some DSP inside a FPGA but I'm running into a problem with defining the coefficients. I want a 1000 element array with each element being 18 bits. I'm running the below code:
ERROR:HDLCompiler:806 - "filter_coeff_15.h" Line 3: Syntax error near "'".
So it doesn't like the single quote for some reason but I don't understand why. My understanding is that this is how you would define an array like this. I use this code with Modelsim and it works perfectly. Why does ISE not like this?
I've tried removing the single quote and it seems to work but I think it's doing something weird and thinking this is a single 18000 element.
Is this valid Verilog? It works in SystemVerilog. I don't think SV was ever added to ISE. you might need to just make it a reg and initialize it in an initial block. That also might allow for initialization using readmem.
You're correct, it appears to be System Verilog syntax. I tried what you suggested by initializing it in a initial block and that worked. And you're right that readmem can do the same thing. Thank you!
