decimal to hex and hex to decimal conversion in ccs pic compiler.
Noman Yousaf
Full Member level 4
Lahore Pakistan
hi
i simply need to convert decimal (8 bit) to hex in CCS. In mikroC, that is so easy to convert by using "bcd2dec" built in function. but in CCS i think there is no any function like that so how can i do?
Easyrider83
Advanced Member level 5
Tallinn, Estonia
unsigned char DecToBCD (unsigned char Value)
  return ((Value / 10) << 4) | (Value % 10);
unsigned char BcdToDec (unsigned char Value)
  return ((Value >> 4) * 10) + (Value & 0x0F);
FvM
Super Moderator
Staff member
Bochum, Germany
The code is right for BCD conversion and should be equivalent to the respective MikroC built-in functions. Hex conversion as asked in the question title is a different thing.
Easyrider83
Tallinn, Estonia
How can I help if I can't understand what does he means?
HEX to string conversion?
void ValueToStringHEX_Byte (unsigned char Value, char * String)
   const unsigned char HEX_Var[17]={"0123456789ABCDEF"};
   * String++ =   ((Value&0xF0)>>4)[HEX_Var];
   * String   =    (Value&0x0F)[HEX_Var];
